8 Replies Latest reply on Apr 14, 2015 8:52 PM by Mike Pogue
    Unable to print in exact size
    Peter Cohen
      Hello, I am using SW 2014-1015 on Windows 7 64-bit. To make things simple, I drew a rectangle of size 150 x 100 cm. Then, I saved the file as a pdf file. Next, I printed it under MacOS (somehow connection between Windows 7 and the printer does not work). I tried varies settings but the printouts could not be exactly measured as 150 x 100 cm. Either it was too large or too small. I use A4 size papers. Any suggestion on how to print the exact size as I designed in SW? Thanks.
