Hello All,
I have recently started using the report publisher to save time compiling results of simulation studies, especially useful when multiple simulations are run on the same part. Lately, however, the report generating tool has become hit-or-miss, often skipping important information like mesh properties or transient response graph. For example, I recently used an h-adaptive sim to run a static stress analysis of a bracket. The final mesh details (as reported from right clicking mesh and selecting "Details") are
Study name: h adaptive (-Default-)
Mesh type: Solid Mesh
Mesher Used: Standard mesh
Automatic Transition: Off
Include Mesh Auto Loops: Off
Jacobian points: 4 points
Element size: 7.81321 mm
Tolerance: 0.39066 mm
Mesh quality: High
Total nodes: 80725
Total elements: 52841
Maximum Aspect Ratio: 3.8601
Percentage of elements with Aspect Ratio < 3: 100
Percentage of elements with Aspect Ratio > 10: 0
% of distorted elements (Jacobian): 0
Time to complete mesh(hh:mm:ss): 00:00:02
Yet the auto generated report contains the following meaningless mesh information table
Mesh Information
Mesh | Solid |
Mesher | Curvature based mesh |
Jacobian | 4 |
Maximum | 0 mm |
Minimum | 0 mm |
Mesh | High |
Additionally, the report contains the following caption-without-an-image for a convergence plot
Name | Type |
Graph1 | h-Adaptive |
BRACKET-h |
does this same thing happen on a block?
does it happen if you dont' do mesh adaptive?
are you using 2015 sp3.0?
