2 Replies Latest reply on Apr 13, 2015 6:10 PM by Kaijiun Cheang
    Method or data member not found
    Kaijiun Cheang
      Hi all,
      I am a newbie in VBA and in attempt to create a macro to do batch file running, by substituting recorded macro into it.
      Attached file is  "open&save as part number" - that had been paste with code.
      "Solidlead" is the file that i recorded.
      As i try to run it, the compiler shows up the warning"method or datamember not found" for some code lines, such as :
      boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDimensionsExtensionLineStyleSameAsLeader, swUserPreferenceOption_e.swDetailingHoleDimension, False)
      If i remove those lines, it runs without problem.
      I wonder what's wrong with the code? If i run solidlead by itself, there is no problem. But if i paste it to the other one, it shows that error.
      Thanks.
