LMLee Macklem11/06/2007
Whenrunning
Cosmosxpress I am told to reduce my mesh size and when I doI get
the error: SolidWorks is unable to obtain
requiredmemory: Please attempt to free some memory and then
pressRetry, or press Cancel to terminate your Solidworks
session. If I free up memory and it is still not enough for
Cosmos to run itwill exit my session of Solidworks. At this
point I should beable to go back into Cosmos and change setting
without it throwingme out of session. My VAR said it uses
both physical andpaged memory. I added 20GB of paged memory
and it did nothelp along with my 2GB of physical memory. I
watch the TaskManager in Windows and it does not use much memory at
all whenrunning. Is Cosmosxpress just a program that should
not beused. I find it works for simple parts but if you
havecomplex weldments it has problems with the solid mesh
andmemory. Is this a Windows issue?
