I had use task to convert SolidWorks Drawing file to PDF.
I want to customize PDF file name when convert complete. Can I insert a value from variable? (picture attachments)
Yes, you can use those variables for file name.
Hi Faur,
You can guide me more specific?
Just to expand on Faur's response. He is correct that a variable can be added but you have to put it between % symbols as I have done below.
Hope this helps
Steven
Hi Steven,
Thank you so much for reply my question. I've implemented the same as you guide image, but it was not successful. You can see my results in the attached image. Do I need to do add anything for the variable created?
hi
see this
S-054527 - How to modify convert task to use variable value from source file in output file name
Hi Earl,
Thank you so much for your solution. I was successful!!!
hi
see this
