I have a model of a kite that was designed using SurfPlan. The problem is that I intend to run a design optimisation in ANSYS, and it needs a parametric model. I've tried to use the 'design table' feature, but as the model doesn't have any associated dimensions, it won't work. Is there any way to make this model 'parametric'? Any help would be appreciated..
I've attached a link to the model below.
Kite model: https://www.dropbox.com/sh/po8gkz08u7vfqru/AADkHzVz8xsqEYUZw6RnMD7Aa?dl=0
I haven't looked at your model (if you hit, use advanced editor, you can attach files here).
There is no magic button to make an imported model to SW parametric. You need to remodel it in SW. The imported model can be used as a template/guide, and you can make relations to it, but you need to remodel.
