Hello all,
as stated above, I'm having an issue with the routing add-in. Whenever I attempt to add any Cpoint to an existing route, I get the following error: "Cpoint is invalid. Please edit feature and redefine geometry." I know that the Cpoints are valid; I can start a route on them without any problem, and I'm using (mostly) the Solidworks default connectors. I'm following the same workflow I was using yesterday, and no problems occurred then. I suspect there is some sort of issue with my software, rather than the models. I have tried closing and relaunching SolidWorks, restarting my computer, and disabling and enabling the routing add-in. Has anyone encountered a similar problem or any suggestions on how to work around this? Thanks.
-Alex
Today I found the actual problem. I'm working in a rather large assembly- trying to attach to a lightweight component was the cause of the issue. By resolving the component I was able to make everything work as expected. Hope this can help someone.
-Alex
