Is there anyone who knows whether its possible to create a Custom hole type for the hole wizard. I would like to be able to add a kind of hole/fitting without having to add several holes on top of each other or have to change the drawing of the hole. I am frequently using up to 20 different high pressure fittings, all using their own design, and it would be nice to be able to select it in the hole wizard.
All I've found is how to add custom sizes of different hole types, but not new types.
Attached is a sample drawing, not exactly the right measurements, but that I will change for all different types I would like to add.
I would like it be possible to change the total depth of the smaller drilled hole, 30mm in this drawing, to the blind and through all.
Is there anyone who has and idea of doing this? if its not possible to add it into the hole wizard, is there any other way to have it made with one click like the hole wizard?
Anyway thank you for your time, and I can add more details if someone is interested.
I would suggest you create a library feature which can have configurations to take care of various sizes and then you can simply drag drop that into the required part/assembly. You can also create you fitting as smart component and create a smart feature. This way when you add the fitting to your assembly, the required features (like hole in this case) would be added automatically.
Please check these posts; Frequently Asked Forum Questions, How to ask a good question in the API forum and Forum Posting for your future reference to get best out this forum
