Save certain sheet with NCP in the sheetname as .DWG
Question asked by Roger Chee on Apr 7, 2015
Latest reply on Mar 1, 2017 by Ulf Nutti
Hi all,
I'm looking for some help to modify a code that that saves certain sheets of my drawings into PDF.
I need the macro to export sheets in my drawings that contain "NCP" in the sheetname as .DWG
Right now, I have the macro to save the exported files to my desktop.
Below is the code that I need help with modifying:
Option Explicit
    Dim swApp               As SldWorks.SldWorks
    Dim swModel             As SldWorks.ModelDoc2
    Dim swDrawDoc           As SldWorks.DrawingDoc
    Dim swModelDocExt       As SldWorks.ModelDocExtension
    Dim swExportPDFData     As SldWorks.ExportPdfData
    Dim boolstatus          As Boolean
    Dim filename            As String
    Dim lErrors             As Long
    Dim lWarnings           As Long
    Dim strSheetName()      As String
    Dim varSheetName        As Variant
    ' Path to which to save PDF file of drawing (I need this to be in DWG format)
    filename = "C:\xxxxxxxxx.PDF"
    swApp.Visible = True
    Set swModel = swApp.ActiveDoc
    Set swDrawDoc = swModel
    Set swModelDocExt = swModel.Extension
    Set swExportPDFData = swApp.GetExportFileData(swExportDataFileType_e.swExportPDFData)
    ReDim strSheetName(0)
    Dim s As Variant
    For Each s In swDrawDoc.GetSheetNames
        If UCase(s) Like "*NCP*" Then
            strSheetName(UBound(strSheetName)) = s
            ReDim Preserve strSheetName(UBound(strSheetName) + 1)
    Next s
    varSheetName = strSheetName
    If swExportPDFData Is Nothing Then MsgBox "Nothing"
    boolstatus = swExportPDFData.SetSheets(swExportData_ExportSpecifiedSheets, varSheetName)
boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportPDFData, lErrors, lWarnings)
