VBA: Assembly Part Locator and Zoom (Issue)
Question asked by Dave Paul on Apr 7, 2015
Latest reply on Apr 8, 2015 by Dave Paul
I am attempting to write a routine that will zoom into a part location, within an assembly.  Hopefully, the routine will locate the part, pull the bounding box, use that data to zoom to the part location.    The issue that I'm having is that the "CreatePoint" method doesn't seem to like what I'm handing it.  It may be the same issue that others are having, but I'd like to confirm it.  The code below is a test routine, but it should give me the results that I was needing.
Thank you for any information,
-Dave
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swPart                      As SldWorks.PartDoc
    Dim swSelMgr                    As SldWorks.SelectionMgr
    Dim swSelComp                   As SldWorks.Component2
    Dim swMathUtil                  As MathUtility
    Dim swSelPt1                    As SldWorks.MathPoint
    Dim swSelPt2                    As SldWorks.MathPoint
    Dim vSelPt1                     As Variant
    Dim vBody                       As Variant
    Dim vBox                        As Variant
    Dim Point1(2)                   As Double
    Dim Point2(2)                   As Double
    Dim spPnt1                      As ISketchPoint
    Dim spPnt2                      As ISketchPoint
    Dim i                           As Long
    Dim bRet                        As Boolean
    Dim comps As Variant
    Set swModel = swApp.ActiveDoc
    Dim comp As Component2
    comps = swModel.GetComponents(False)
    For i = 0 To UBound(comps)
        Set comp = comps(i)
        If comp.Name2 = "Part23-1" Then
          Debug.Print "Name: " & comp.Name2
          Debug.Print "GetSelectByIDString: " & comp.GetSelectByIDString
          swModel.Extension.SelectByID2 comp.GetSelectByIDString, "COMPONENT", 0, 0, 0, False, 0, Nothing, 0
          Set swSelComp = swSelMgr.GetSelectedObjectsComponent(1)
          Debug.Print "Selected Name: " & swSelComp.Name2
          If swSelComp.Visible = swComponentVisible Then
            vBox = swSelComp.GetBox(False, False)
            Point2(0) = GetMax(vBox(0), vBox(3), Point1(0))
            Point1(0) = GetMin(vBox(0), vBox(3), Point2(0))
            Point2(1) = GetMax(vBox(1), vBox(4), Point1(1))
            Point1(1) = GetMin(vBox(1), vBox(4), Point2(1))
            Point2(2) = GetMax(vBox(2), vBox(5), Point1(2))
            Point1(2) = GetMin(vBox(2), vBox(5), Point2(2))
            Set swSelPt1 = swMathUtil.CreatePoint(Point1)
            Set swSelPt2 = swMathUtil.CreatePoint(Point2)
            Call ZoomToSelection(swSelPt1, swSelPt2)
    Next
