I have a part that has a fairly complex machining path. In the part below, the path is a spline, and the floor twists as the slot progresses.
I can make the geometry using the conventional modeling tools, but wanted to investigate different techniques.
The geometry I need could be duplicated with an endmill, but the path and angle would need to be defined by splines. Is there a way to 'Cut' the part just as one would using a 5-axis machine?
Ahh, it appears you are right. I have experimented a bit and discovered a method to guide the orientation of the tool. You can loft a surface between the path and the guide curve, then when you create the solid sweep select the edge of that surface as your path (not the original sketch) and set the path alignment type to "All Faces". Now the sweep should follow that surface orientation (which was controlled by your guide curve). If you have SW2014 or later you can see my attached example.
