1. In all of my searching through tutorials and examples I find many ladder diagrams. Why are there little to no examples of point-to-point schematics? Am I using the wrong search terms?
2. Can somebody please direct me to good examples of point-to-point style circuitry that illustrate the full functionality of SolidWorks 2D/3D?
3. Are there any experienced SolidWorks 2D/3D users out there that can offer opinions regarding SW2D/3D efficiency in point-to-point applications?
Any input is appreciated.
Regards,
James
I'm no expert but I use SWE 2D for point to point schematics almost exclusively. I haven't really gotten into the 3D.
We are an R&D lab and build numerous prototypes. I am responsible for designing the electrical systems of the prototypes. We build almost always using point to point wiring because when working on prototypes you often have to move things around. Point-to-point makes that easier because the wire is not in a big cable bundle or harness. We use a lot of cable trays through out the systems to help keep things neat.
The way we lay out schematics is different as well. We try to work them left to right, with power on the left, instrument/sensor/device in the center and control/readout on the right. We try to show the complete logical line between power, instrument and control/readout on the same page.
Working with SWE 2D is sometime a frustrating experience. My biggest gripe so far is the terminal blocks. We generally use terminal blocks for power distribution. A particular voltage comes in on one terminal and a line of terminals are tied together using jumper bars. Then each device pulls it's power from one of the jumpered terminals. Practically, this works great but SWE doesn't cooperate very well when I want to put a single terminal point on the left hand side of a schematic and run it to the device. I've found a workaround but it is kinda ugly. Likewise, I don't use the auto-generated PLC drawings as I want to have my PLC points on the same page as the device. I just use a symbol that only includes the point I want. That works fairly well but you have to be careful as when the symbols are placed they are number sequentially, there is no way to select a specific point to place a symbol for.
I never use the single line drawings or the hybrid drawings as it is just extra work for no extra benefit.
Like I said I haven't really used the 3D much. Since I'm not make multiple copies of the wiring I don't really need to know lengths or build harnesses. The one thing 3D would be useful for is determining clearances and cable tray fill. I've had a few systems where the cable trays were over flowing with wires.
