3 Replies Latest reply on Mar 8, 2017 2:41 AM by Andreas Wegmueller
    Automatic rendering all Configuration to file
    Aviev Akhmad
      I  use sldwork api to render multiple defined configuration.
      The macro is working pretty well when i put msgbox between configuration rendering, as I have 320 configurations I would not put this msgbox.
      unfortunately when I remove the msgbox the script didnt work..
      anyone know what would be the problem?
      do you think timed msgbox will solve the problm? (so far I could not find any working timed msgbox in solidworks API)
      or is there any function in solidworks API that able to wait render process before execute next script?
      and here is the script
      Sub RenderAllConfig()
          Dim swModelView As SldWorks.ModelView
          Dim vConfNameArr As Variant
          Dim sConfigName As String
          Dim start As Single
          Dim i As Long
          Dim bShowConfig As Boolean
          Dim brefresh As Boolean
          Dim bRebuild As Boolean
          Dim rendering As Boolean
          Dim bRet As Boolean
          Dim Ioutfile As String
          Dim swRayTraceRenderer As SldWorks.RayTraceRenderer
          Dim swRayTraceRenderOptions As SldWorks.RayTraceRendererOptions
          Set swModel = swApp.ActiveDoc
          Set swModelView = swModel.ActiveView
          ' Access PhotoView 360
          Set swRayTraceRenderer = swApp.GetRayTraceRenderer(swPhotoView)
          ' Get and set rendering options
          Set swRayTraceRenderOptions = swRayTraceRenderer.RayTraceRendererOptions
          ' Display render window
          'rendering = swRayTraceRenderer.InvokeFinalRender
          'Debug.Print "File = " + swModel.GetPathName
          vConfNameArr = swModel.GetConfigurationNames
          For i = 0 To UBound(vConfNameArr)
              sConfigName = vConfNameArr(i)
              bShowConfig = swModel.ShowConfiguration2(sConfigName)
              'bRebuild = swModel.ForceRebuild3(False)
              'brefresh = swModelView.EnableGraphicsUpdate
              MsgBox ("Rendering :" & sConfigName)
              start = Timer
              Ioutfile = "d:\render output\" & sConfigName
              rendering = swRayTraceRenderer.RenderToFile(Ioutfile, 0, 0)
              Debug.Print "  Configuration    = " & sConfigName
              Debug.Print "  File name        = " & Ioutfile
              Debug.Print "  Rendering        = " & rendering
              Debug.Print "  Time             = " & Timer - start & " seconds"
           Next i
          ' Close render
          rendering = swRayTraceRenderer.CloseRayTraceRender
        • Re: Automatic rendering all Configuration to file
          Keith Rice
          I have never had to create a pause when rendering configurations, so I am not exactly certain what the problem is. However instead of using a message box you can sleep the thread like this:
          #If VBA7 Then
          Private Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
          #Else
          Private Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
          #End If
          Sub Sleep()
              Sleep 1000 'Implements a 1 second delay
          This code only works in VBA. If you're in .NET, then you need to use System.Threading.Thread.Sleep().
          Keith
          SolidWorks API Tutorials
            Mikle Kov
            Not a very elegant solution, but eventually worked.
            Move the starting and closing PhotoView 360 app in cycle.
            Set swRayTraceRenderer = swApp.GetRayTraceRenderer(swPhotoView) ' Access PhotoView 360
            Set swRayTraceRenderOptions = swRayTraceRenderer.RayTraceRendererOptions ' Get and set rendering options
            '******** RENDER
            rendering = swRayTraceRenderer.RenderToFile(Ioutfile & ".png", 0, 0)
            '******** Close render
            Next i
            By the way, if the configuration name has a point.
            Do you have problems with the correct name in your case.
            For example the configuration name: 2GN12.5K
            You use: rendering = swRayTraceRenderer.RenderToFile(Ioutfile, 0, 0)
            You'll get: 2GN12.png
            I use:  rendering = swRayTraceRenderer.RenderToFile(Ioutfile & ".png", 0, 0)
            I get: 2GN12.5K.png
              Andreas Wegmueller
              I had the same problem, but with this timed msgbox it works.
              The first part
              #If Win64 Then '64?
                Private Declare PtrSafe Function MsgBoxTimeout _
                Lib "user32" _
                Alias "MessageBoxTimeoutA" ( _
                ByVal hwnd As LongPtr, _
                ByVal lpText As String, _
                ByVal lpCaption As String, _
                ByVal wType As VbMsgBoxStyle, _
                ByVal wlange As Long, _
                ByVal dwTimeout As Long) _
                As Long
              #Else
                Private Declare Function MsgBoxTimeout _
                Lib "user32" _
                ByVal hwnd As Long, _
                As Long
              #End If
              The second part
              Sub btnMsgbox()
                Call MsgBoxTimeout(0, "This message box will be closed after 1 seconds ", "SolidWorks BatchRenderer", vbInformation, 0, 1000)
