When I start a rout by the Drag/Drop option, I get the following error message with flanges above 14" : "No matching configurations are available for elbow 'piping\elbow\90 degrees\90deg lr inch elbow.sldprt' Please customize the template and see all available configurations.". If I try to customize and start, the error message: "No valid configuration could be found for this elbow" appears. Besides that, the dialog box that appears when dropping a flange, "Select a configuration", cropped, and I can't enlarge it with the cursor. Do I need to download extensions for the library? Does anyone know how to solve these problems? Your help would be greatly appreciated.
The easiest thing to do is to just create new configurations for the sizes you want. just right click on a current config. in the feature tree and select "add new configuration". once you do this it will ask you to name the new one, so do that appropriately and make sure it is saving the new one to the same file location. then just edit your diameter and bend radius for your new size. you may have to add c points and routing points, i cant remember if they will come in with the new configuration or not, but if they don't it is easy enough to do and i cant help with it. hope this is helpful
