I have not yet found a good way to PRINT the workflows from the EPDM Admin Tool. Can anyone provide a method for getting high-resolution output to a printer, or to a PDF file?
There is a print option in the workflow editor under the file menu.......not sure when they added it though.....maybe 2014 since that's when they added the ability to zoom and pan around the workflow.
I have been using Snagit. If you have a large workflow that doesn't fit in your editor window, you don't have to zoom out, or lose any quality, using the scrolling capture feature. So that is another option.
My best workaround is to Print as XPS DOCUMENT and the print that document! that get's you around the Blank Sheet issue!
Thanks for all the suggestions, but to use a worn out phrase, "been there, done that".
My workflow is rather large in terms of real-estate that it occupies on an 11x17 sheet of paper. I can't get the resolution needed to permit the SMALL text to be read. Maybe I just need smaller workflows............
Hi! What about integrated solutions, like FolderMill (http://www.foldermill.com/). This solution is ideal for printing workflows.
David;
I use the Snipping Tool (Win7)
and they save as .png.
They come out clear and the editing works well - makes it manageable to increase or decrease.
I prefer it over the built in print feature
Hope this helps
MattP
