One of the customer require, to know the rise in the temperature due to friction. How best this can be simulated.
Rajesh
Rajesh
If you know the friction coefficient, and you know the speed, you can compute the power, which you can plug into SolidWorks Simulation as a boundary condition. These are the same pieces of information I'd assume you'd need to do this in Abaqus. If you don't know the friction coefficient, you can do some easy experiments to get it. You should probably do them anyway, rather than relying on publish coefficients.
not supported in SWX Sim. I don't think there is a work around, not one that comes to minds at any rate........It is supported in ABAQUS and likely other codes.
