Hello everyone from a new Solidworks user
I am trying to build a part for practice and I think I am nearly done but can't seem to mate the cylinders (wheels) to the holed strip.
I've attached my assembly file and the picture of what I am trying to accomplish.
I've mated it so that the cylinder only moves in the direction normal to the hole but I can't get it to "fit" into two holes.
I think the problem is the tip of the cylinder is 25mm but the size of the hole is 25.2 mm.
Also, I've done smart fastener on the top board but I need to bolt down the cylinder against the holed strip but it is not working.
It's only recognizing the holes of the strip. Do I have to do this manually?
Any help would be greatly appreciated.
Thank you!
Hello Bruce Lee,
Please use Pack and Go to save your assembly files, and then attache them. Previous archive contain only assembly without parts.
Thank you,
Adrian Ilie
