Good evening all,
I am new to this forum, I could not see a clear introduction thread so a little intro! I work for Ford UK, and am currently in the middle of a BEng which requires some 3D simulations. Previously I used AutoCAD but only for 2D so as expected, I am encountering a few problems that SW Help and Youtube aren't quite clarifying; is it appropriate to just post queries as I have done here? I apologise if not, if someone could let me know that would be appreciated. I am currently using SW2008, but hopefully I will have access to a PC with SW2012 from next week.
Regarding my issue; I have extruded a simple rectangle which drafts outwards (hopefully the image can be seen below), is there a way to trim the face off as I only require the outwards draft on the longitudinal axis?
http://i61.tinypic.com/2upba0h.jpg
Louis
Louis
No option for doing that in one move. I always liked SDRC's option to select faces to draft. Perhaps SW will have it one day.
Usually I find it best to do a straight extrude and then add a draft feature. Sometimes it works best to extrude the draft and cut off extra material (it is disappointing that the draft feature will not create 0 degree draft).
Dwight
