I have quite some experience in VBA programming in Excel/Access/Outlook, but I'm completely new to VBA-programming in Solidworks and it seems I'm overlooking some very basic knowledge, because I've found a quite straight forward macro on this forum to export a specific bom-template, see below, but sadly it doesn't come past the third line...
Dim swBOMTable As SldWorks.BomTableAnnotation
Dim swTable As SldWorks.TableAnnotation
Dim swAnn As SldWorks.Annotation
Const BOMTemplate As String = "I:\Templates\Tables\Standard Bom\bom-export.sldbomtbt"
Const OutputPath As String = "G:\Stuklijsten\"
Dim ConfigName As String
Set swModel = swApp.ActiveDoc
ConfigName = swModel.GetActiveConfiguration.Name
Set swBOMTable = swModel.Extension.InsertBomTable(BOMTemplate, 0, 0, swBomType_e.swBomType_Indented, ConfigName)
Set swTable = swBOMTable
swTable.SaveAsText OutputPath & "BOMTable_" & swModel.GetTitle() & ".xls", vbTab
Set swAnn = swTable.GetAnnotation
swAnn.Select3 False, Nothing
swModel.EditDelete
Can somebody figure out why I keep getting the run time error '91 Object variable or With block variable not set, this would be very much appreciated...
