How 3D Visualization Costs Could Be Reduced?
Question asked by Mr Jinendra Shah on Mar 31, 2015
If We Explained the 3D Process Better to Clients
3D Visualization requires a keen understanding, which is further forwarded to the clients in order to give them a clear picture. This will make them understand the workflow followed by you. A lot of time is wasted, when your client is not clear about the way you work, or the process you are following. Sometimes due to misunderstanding, the client could end up giving you a re-doing instruction, which is again a loss of time and money. Such circumstances could off course be avoided, if one could explain the client better. It is you who have to take the initiative. You have to beknowledgeable and experienced enough to make you client understand the workflow which will avoid wastage of time and effort in 3D visualization.
You need to make sure that your client understands the process well, and that you have all the necessary information, which the client has to provide. There should be no communication gap. Such gaps are the main cause for misunderstandings and errors in the outcome. Keep communicating on a regular basis, so that you do not miss any update or change in the information that is required in the process of 3D Visualization. It is always smart to provide the client with detailed proceedings, on each and every step that is involved in the project. Sometimes, the clients demand for sudden changes, which is again a waste of time and creativity. It is also important to analysis the project well and note down the things which would require much attention. Quote a price, after giving a thorough look out for the client’s project. Do not forget to give a detailed statement, on the quote. This will show genuine practices on your part, which will help build a strong relationship with the client.
Don’t forget to inform him the time which will be required for the completion of his project. In case you feel, you would cross the stated date or time, do not hesitate to give him prior information on this. After all, client needs the best work from you. If you feel the demands are too complicated, then try to meet up, and make your client sit beside you, to avoid confusion. You will really enjoy the appraisals that you will get, for your quality and satisfied work. Show your client, that you have enough talent to meet up his demands in terms of colors, textures, materials and framework. The best thing would be to send follow-up mails to the client on a regular basis, attaching the images and drawings that would be included in the work. Show him the framework. It is better to make changes before you implement you plan to the main levels. Make immediate changes during the initial level, and see to it that you start with a framework or a plan, which completely satisfies the client.
I am sure that these points are worth noticing, and following such professional rules in 3D visualization, could save a lot of time, money and effort. All the three things are of keen importance to an artist of any field. So do not confuse yourself and the client. The key tip is to finalize the work, before you could start it. You will not land up re doing the work and thus, you will save a lot of money, which would otherwise be a loss for you or your company.
