Hey There Guys!
I have a 20m3 sulfuric acid tank made of polyethelene. I have a cut extruded hole on the side of the tank drawn on the front plane. I have to rotate this hole 45° from the front plane with the moving face feature.
But when I execute this command a part of the material just disappears?
Just a simple question: Why?
Can you help me with this problem?
Thank you in advance.
You're trying to rotate a feature and NOT the face which is why you're seeing those components /bodies vanished/merged.
Here is the updated file with correct method of moving face.
