1 Reply Latest reply on Mar 29, 2015 8:35 AM by Deepak Gupta
    up to next hole callout gives  wierd value
    Ben Galili
      Hi.
      So I have a hole ..  its a custom hole wizard hole as seen in Fig 1.
      now in the drawing the callout appears as it is seen on Fig 2.. instead of saying that the 1.8 hole is THRU, it says that its 11.001 deep!  where the actual dimension is actually 11 precisely.
      when I switch the end condition to Through All then its fine and the callout says THRU. But this Bug might cause me problems in other parts in which I have to use Up To Next as the End condition...
      I also attached the part and drawing (Although the color scheme might not works for  you as I changed it..), The hole callout file (search for "XACT ISO" in the file).
      Plz Help.
      Regards
      Ben
