0 Replies Latest reply on Mar 27, 2015 8:22 AM by Marc Raby
    Drawing note appearing as broken reference. Cannot delete
    Marc Raby
      Hi, I am working on a drawing, and I added a note in a while ago, but then needed to delete it. The initial delete appeared fine, but then when I tried to add in another note, the old one appeared and showed green as a broken reference. If I go to edit the sheet format, the old note will disappear, but then reappear after I save. It will also show up if I try to print. Both of these notes have linked material properties within them, which I think may be causing the issue.
      Anyone have any clues for how I can get this old note to delete?
      Marc
