DGDeepak Gupta27/03/2015
As the title explains, Configuration Publisher doesn't showing dynamic updated values from Design table. The static values work fine but not the one which are dynamic or updates based on some selection. In the attached file, the design table Range F7:G7 updates based on the plane distance. The design table updates correctly but in Configuration Publisher, it shows one fixed/static value and doesn't update with any changes in F7:G7. I've tried on various files with same results. Is this an intentional behavior OR a bug?
I've attached a video showing the issue plus the SW2014 files in case someone wants to check it out. Thanks in advance for any pointers.
