One of the users have large screen resolution and because of that text inside the drawings distorted, but when I change the resolution to small or medium the text in the drawings shows fine. The user has problem with her eyes so we have to use large screen resolution, All the software is up to date.
OS Windows 7 Prof 64 bit
Solid works version 2015
Any suggestions will be great.
thank you in advance.
If I understand you correctly, you are changing the resolution not the dpi.
If that is the case I would probably try to adjust the DPI settings. You can also set custom text size (DPI)
