Hello. I am trying to apply a material to a part, which seems to work, but when I try to select anything in the list on the right, nothing happens. In the attached image, for example, "polished pine 2d" is selected, but I can't select anything else in the list, or use the scroll bars to navigate in the list.
Is this normal? How can I select the other variations of Pine?
I'm using Solidworks Student 2014-2015 Version 22.2.0.0040 (11.9.0.0.87342.0) (4.1)
Thanks, Paul
Not a limitation. I´m on SW15 premium, works the same for me.
If you want to change "Solidworks Material" you can copy it to your own database and change everything in it you want. Since you you only want to alter the appearance I suggest you do it here , see image.
