Good Day fellow SW users,
Quick question...I'm working on a surface (we'll call it S1) that has a hole. I've filled that hole with 'Filled Surface' (we'll call that filled surface S2) and I've knitted S1 and S2 together. Now the blue edge line initially around S2 has become a black line since it is joined to S1...all well and there.
Now I would like to remove the black line border around S2 so that both faces are completely merged and appear as one surface with no trace of S2 ever being there.
I saw some people say to use the 'Tangent lines Removed' option in View-Display but that only hides the black border line...I want it completely removed.
Is this possible?
Thank you,
David Flemming
Hi David,
No, it is not possible to remove this line (because it is topology that is necessary because of the fill surface you created.) Now, let me ask you what your are trying to do? Is this a hole that was created by you or someone else (imported model?) If so, then you might be able to use the Delete face on the default option (delete and patch.) This will find the original face and extend it. Also you might want to try the insert>Surface>Untrim to also try and regain the original surface.
A screen shot would help...
Mark
