We seem to be having some issues with mapping variables and Microsoft Word. When I have a word document that moves through a workflow with an increment revision transition
the document becomes the incremented revision but the new revision is not reflected in the variable internally within the file.
So let me list the different parts of this issue:
EPDM SP 15.1 (B745) – upgrading to 15.2.1 on Thursday evinging
Variable:
Block name – CustomProperty
Attribute name – Revision
Extensions - .docx, .dot, .xlsx, pdf, etc.
File Card – “Revision” text field selected:
Show in Explorer
Updates all configurations
Folder data card variable (I’ve tried this as a “text value” but it didn’t fix the issue)
Default overwrites (checked)
Workflow transition:
Set Revision – set variable, run for files, variable=Revision, value=%nextrevision%
Increment Revision – Inc. Revision, run for files
Word Document:
Advanced Properties, Custom – name=Revision, type=text, value=00
Quick Parts, Field – DocProperty, Revision
After transitioning the document the file card and history show that the revision is at 01 but after updating the field inside the file the value still shows 00 and not 01.
By the way, our excel files that use the same workflow, data card, and variable do not have any problems with showing the correct revision. So I verified that the variable has a .docx extension. This makes me think that it is something in the word document.
Any ideas?
If I recall this correctly you need to enable macros in word. Get the 'Developer' group into the word menu (can't remember how to do this) then go to 'Macro Security and enable all macros.
What happens if this is not enabled word will not read the new property into the document even though it is there in the properties and update the field. This can be triggerd manually but if you enable macros it will do it automatically everytime you open the document. It seems that this is unique to word.
