I have a linked design table called "design table.xls" ina
part file. Recently it started saving itself using the name:"design
table.xls_new" everytime I save the part file.The first time I
save, there is no problem, every subsequent savesafter that,
solidworks prompts with the message: "A file namedc:\design
table.xls_new already exists in this location. Do youwant to
replace it?" With options Yes, No, Cancel. I havenever had this
prompt in the past with any other design tables. Howcan I get rid
of the prompt or prevent the "designtable.xls_new" file from being
written to the disk? Thank you,Nayshil.
Take a look at Tools - Options - System Options:
Update out-of-date linked design tables to. Determines what happens to linked values and parameters if the model and the design table are out-of-sync.
Prompt. The software prompts you when you open a document with a design table that is out-of-sync with the model.
Model. The design table updates with the model's values.
Excel File. The model updates with the design table's values
