Perhaps the feature I'm looking for already exists. I have an assembly with doors, and I click and drag to pivot the doors. Right now, the door will swing into the model, which obviously wouldn't happen in the real world. When I have to close a door, I create a mate to get to door in the correct position, and then suppress the mate. To close the door, I unsuppress the mate. This is purely to check clearances and to keep my model in the correct position for drawings.
I know that collision detection already exists, but is there a way to set it to automatically run while I'm dragging parts around? Better yet, is there a way to turn it on and off with ease? Better still, could I set this enable/disable command to a hotkey? My ideal scenario would go as follows:
- I need to close a door to check clearances or something.
- I enable the collision detection, preferably with a hotkey.
- I drag the door closed, and it stops when it comes in contact with the doorframe. There are no mates at all.
- I disable the collision detection to continue working as normal.
I think this would be cool! If it doesn't exist, it would be a cool feature to add. Thoughts?
You can use angle limit mates to swing it and make it stop at the angles you prefer.
You can also use Collision detection.
There is a check mark to "stop at collision" in collision detection to make part stop when it hits something. It´s in the move command, you could make a shortcut for that.
