I am searching for a setting in the User interface that would prevent that Sketch or Wire body to be visible through solids or surfaces. Actually, with the default settings, if a sketch is placed behind a solid body, you see it as if it is place on front of it.
Thank you for your support!
David Bourdages
I don't believe there is an option like that. I'm not sure when this would be desired. But one thing that might give you what you want is to exturude a surface from the sketch with a really tiny distance so that is just looks like lines.
