Is it possible to cut a part with another part in an assembly.
I'm trying to make a model of vise soft jaws that are cut to the shape of another part. I cannot find a way to cut, when I open "cut with surface" nothing happens, it will not select any face. What is an easy way to make this work? I just want to cut the blue vise with the purple part.
Use the Intersect Feature. It is not of the Feature Toolbar as standard. You will need to add by:
Use the Search Command (Top RH corner) and type Intersect
OR
Tools>Customize> Commands>Features
