IDisplayData::GetLineAtIndex3 problem after Break
Question asked by Joecel Torres on Mar 19, 2015
Dear Everyone,
I have a utility that creates horizontal dimension and places the dimension text in the middle of the 2 extension lines.
To determine the middle of the extension lines, I used IDisplayData::GetLineAtIndex3 to get the data needed then perform the computation as shown below:
IDisplayData disData = (IDisplayData)tempDim.GetDisplayData();
 double[] lineData1 = (double[])disData.GetLineAtIndex3(0);
 double[] lineData2 = (double[])disData.GetLineAtIndex3(1);
 // Calculate center;
 double center = lineData1[4] + ((lineData2[4] - lineData1[4]) / 2.0);
The utility works fine until I had to insert a break(View:: InsertBreak) in one of the drawing views that I`m working on,
the dimension text position is being placed in the wrong position.
Upon investigation, I found out that the value of lineData1 and lineData2 interchanged so the formula was affected.
I tried deleting the break line then re-create dimensions, and then the text was placed in the right position.
Based on this behaviour, I concluded that the break line is causing the problem, but I may be wrong.
Question:
Is there a way to prevent IDisplayData::GetLineAtIndex3 from interchanging the lineData1 and lineData2?
If none, what alternative function can I use to position the dimension text in the middle?
Thanks is advance.
Best regards,
Joecel
