RPRod Paslowski18/03/2015
Option Explicit
Dim swApp                       As SldWorks.SldWorks
Dim swModel                     As SldWorks.ModelDoc2
Dim swDraw                      As SldWorks.DrawingDoc
Dim swView                      As SldWorks.View
Dim swCenterLine                As SldWorks.CenterLine
Dim swcentermark                As SldWorks.CenterMark
Dim swAnn                       As SldWorks.Annotation
Dim ColorInt                    As Integer
Set swModel = swApp.ActiveDoc
ColorInt = 255
'check to see in a drawing is open
If swModel.GetType = swDocDRAWING Then
    'a drawing is open
    Set swDraw = swModel
    Set swView = swDraw.GetFirstView
    'Debug.Print "File = " & swModel.GetPathName
    'sort through all the views on this sheet
    Do While Not swView Is Nothing
        'Debug.Print "  View = " + swView.GetName2
        'find the center lines in this view and change their color
        Set swCenterLine = swView.GetFirstCenterLine
        Do While Not swCenterLine Is Nothing
            Set swAnn = swCenterLine.GetAnnotation
            'Debug.Print "    Name       = " & swAnn.GetName
            'swModel.DeleteEntityName swAnn.GetName
            'LCOLOR = swAnn.Color
            swAnn.Color = ColorInt
            Set swCenterLine = swCenterLine.GetNext
        Loop
        'find the center marks in this view and change their color
        Set swcentermark = swView.GetFirstCenterMark
        Do While Not swcentermark Is Nothing
            Set swAnn = swcentermark.GetAnnotation
            Set swcentermark = swcentermark.GetNext
        Loop
        Set swView = swView.GetNextView
    Loop
Else
    'a drawing is not open
    MsgBox "This macro requires a drawing to be the active document", vbOKOnly, "ANNOTATIAN COLOR CHANGE"
