In an ASM you can set individual component references for each part even if they are copies of a part.
Is there a way to link a text in a PRT to the corresponding component reference?
E.g.:
-having two identical valves in an ASM by means of having the same part in the same configuration
-setting the component reference to BV-01 and the other BV-02 while being in that ASM
(I know it is then possible to have a note on a drawing of that ASM that links to those references)
-seeing those mentioned on the part itself
I can't see it being possible but I don't mind being proven wrong.
