Our company follows a set of project numbers allready.
i want the epdm project file structure to have the same numbering
so when i create a project a template is allready prepared now i just want too type in a custom project number, instead of it being pre selected by EPDM
Hi Martin
If I understood correctly, you want to type the project number instead of EPDM creating one. If you are working with templates, you can create a template card that has a textbox in which you can type your number, and then link this number to the folder card or the file cards inside the folder you create to create your projects; even you can put this typed number in the filename.
regards,
Alex P.
