Recently upgraded from SolidWorks 2014 Premium to 2015 Premium SP 1.1
Latest issue is Circular Pattern does not work on Bodies, only Features.
I have attached a picture of the Circular Pattern Property Manager, you can see the space beside the "Bodies" label has no check box. Only the "Features and Faces" has a check box.
If I create a solid or surface and want to array it around an axis, when I try to select the body, nothing happens, or it goes to the Features box, which then gives me an error saying"wrong type.."
I called my VAR tech support, tried a few things, nothing. His recommendations was repair the installation, then check. I did this, no change.
Final suggestion was a re-install of 2015 from scratch.
SO , I am asking here first incase someone else has had the same problem.
Steve
