3 Replies Latest reply on Mar 28, 2015 11:34 AM by Kasun Udayanga
    How to access selected edges respectively?
    Kasun Udayanga
      Number of edges in a model are selected before run the macro. When the macro is run ,it should iterate through each and every edge separately. I will include another  program in that loop which will create points on that edges. Sample model which have selected edges is attached herewith too.
        • Re: How to access selected edges respectively?
          Santosh Pawar
          You need to use GetSelectedObjectCount2 Method (ISelectionMgr) in combination with GetSelectedObject6 Method (ISelectionMgr) to process all selected edges.
          Links to sample macros can be found here,
          2015 SOLIDWORKS API Help - GetSelectedObjectCount2 Method (ISelectionMgr)
              Kasun Udayanga
              Thanks for your information. But i do not get clear picture about how to do it. BR.
                Kasun Udayanga
                I have tried with two Methods which you have mentioned. But it failed to give required functionality. I have inserted the VBcode used for the macro too.
                Best Regards.
                Private Sub CommandButton1_Click()
                create_points
                End Function
                ' Preconditions:
                '          (1) Part or assembly document is open.
                '          (2) Edge is selected.
                ' Postconditions: Six, evenly spaced, reference points are created on the
                '          selected edge.
                Private Function create_points()
                    Dim swApp           As SldWorks.SldWorks
                    Dim swmodel         As SldWorks.ModelDoc2
                    Dim swFeatMgr       As SldWorks.FeatureManager
                    Dim vFeatArr        As Variant
                    Dim vFeat           As Variant
                    Dim swFeat          As SldWorks.Feature
                    Dim swRefPt         As SldWorks.RefPoint
                    Dim swRefPtData     As SldWorks.RefPointFeatureData
                    Dim swMathPt        As SldWorks.MathPoint
                    Dim nStatus         As Long
                    Dim bRet            As Boolean
                    Dim pointData       As String 'store the point coordinates data of the relevant point
                    Dim noOfPoints      As Integer 'stores number of points in a edge
                    'to get edge length
                    Dim swEdge          As Object
                    Dim swCurve         As Object
                    Dim vcurveparam     As Variant
                    Dim edgeLength      As Double
                    Dim noOfEdges       As Integer
                    Dim obj             As Object
                    Set swmodel = swApp.ActiveDoc
                    Set swFeatMgr = swmodel.FeatureManager
                    ' for edge length
                    Set swSelMgr = swmodel.SelectionManager
                    'Get number of selected edge count
                    noOfEdges = swSelMgr.GetSelectedObjectCount2(0)
                    MsgBox ("no of selected edges : " & noOfEdges)
                    'Open the text file
                    Open "D:\test.txt" For Append As #1 ' modify starting from end of the file
                    'Line number for the code
                    Dim N As Integer
                    N = 100 'initialized
                    Dim i As Integer
                    For i = 1 To noOfEdges
                        Set swEdge = swSelMgr.GetSelectedObject6(i, 1)
                        Set swCurve = swEdge.GetCurve
                        'get the curve parameters
                        vcurveparam = swEdge.GetCurveParams2
                        'get edge length
                        edgeLength = swCurve.GetLength2(vcurveparam(6), vcurveparam(7))
                        'calculate number of points
                        noOfPoints = edgeLength * 10 / cb_distance.Value
                        'An edge must be preselected
                        vFeatArr = swFeatMgr.InsertReferencePoint(swRefPointAlongCurve, swRefPointAlongCurveEvenlyDistributed, 0#, noOfPoints)
                        For Each vFeat In vFeatArr
                            Set swFeat = vFeat
                            Set swRefPt = swFeat.GetSpecificFeature2
                            Set swRefPtData = swFeat.GetDefinition
                            Set swMathPt = swRefPt.GetRefPoint
                            'Get point coordinates and print to the text file
                            pointData = "N" & N & " G01 " & " X" & swMathPt.ArrayData(0) * 1000# & " Y" & swMathPt.ArrayData(1) * 1000# & " Z" & swMathPt.ArrayData(2) * 1000#
                            'override to txt document
                            Print #1, pointData
                            N = N + 2
                        Next
                        Debug.Print i
                    Next
                    'close the text document
                    Close #1
                    MsgBox ("Points created ")
                End Function
