"...You may need to rerun (I did that a bunch of times) or copy the correct result files to working directory and reopen the document." What does this actually mean I should do?
I ust trying this out for 1st time and getting nowhere...:(
BTW, the edit feature on this posting site does not work well at all...(third try to get corrected text in place ....)
1. rerun the simulation
2. shut down the software and move the files to the results directory and rerun
it means that it can't find the results associated with your simulation for some reason. maybe you moved them or they didn't get saved or maybe you didn't check out of pdm
