2 Replies Latest reply on Mar 17, 2015 5:27 AM by Habib Ghalamkari
    SW 2015 Drawing Crashes
    Habib Ghalamkari
      I have a trouble with 3 solidworks files. As I create a drawing and drag a view into a sheet, SW crashes.
      One of the files that causes this problem is attached.
      Open the file, create a drawing out of one of your templates. As soon as you drag Top View to the drawing Solidworks Crashes.
      If you drag left view to the drawing and click to place the view, solidworks doesn't crash, but it locks
      The cursor or the mouse moves, but nothing happen if you click any button around the screen.
      If I Suppress the holes and the Linear pattern, I have no problem.
      I've deleted the holes several time and added them again, but the result is the same.
      I've also tested this file with two other PCs, and ended up with the same results.
      Only three files are showing this problem. Any other files behaves normally.
      I can start a new file from scratch, but I'm curious to know why these files behave this way.
      the files doesn't show any problem in the assemblies they've been used in.
      Solidworks 2015 Sp2
      Windows 8.1 x64
      16GB Ram
      I'll appreciate if you take your time and take a look at the file.
      thank you
