14 Replies Latest reply on Mar 17, 2015 12:53 AM by Deepak Gupta
    Macro Insert Component into open assembly
    Tiana Rosser
      I don't have any experience with programming languages so I am struggling to write a program which will insert a specific part into the current open assembly. I am using solid works 2013.
      Could someone please write the code required to do this :-)
        • Re: Macro Insert Component into open assembly
          Deepak Gupta
          Try these codes:
          Option Explicit
          Dim swApp As New SldWorks.SldWorks
          Dim swModel As ModelDoc2
          Dim Part As SldWorks.ModelDoc2
          Dim swAssy As AssemblyDoc
          Dim AssemblyTitle As String
          Dim sCompName As String
          Dim errors As Long
          Dim warnings As Long
          Sub Main()
              Set swModel = swApp.ActiveDoc
              ' Get title of assembly document
              AssemblyTitle = swModel.GetTitle
              'Part details to be added
              sCompName = "Add Part path and namer here with extension"
              'Open that specified part
              Set Part = swApp.OpenDoc6(sCompName, swDocPART, 0, "", errors, warnings)
              ' Activate the assembly so that you can add the component to it
              Set swModel = swApp.ActivateDoc3(AssemblyTitle, True, swUserDecision, errors)
              Set swAssy = swModel
              ' Add the camtest part to the assembly document
              swAssy.AddComponent5 sCompName, swAddComponentConfigOptions_CurrentSelectedConfig, "", False, "", 0, 0, 0
              swModel.ClearSelection2 (True)
              swModel.ViewZoomtofit2
