ExportFlatPatternView (flat patterns to dxf's)I
Question asked by Jason Bourne on Mar 16, 2015
Latest reply on Mar 17, 2015 by Jason Bourne
I am trying to write a Macro to automate the export of flat patterns from SW SLDPRT files containing a single Sheet-Metal part and associated Flat-Pattern.
I have gone through the forums and other online sources and my current macro is as follows:
Function ExportFlatPatternDXF(ByVal filePath As String) As Boolean
    Dim swModelDocExt As SldWorks.ModelDocExtension
    Dim boolstatus As Boolean
    Set swModel = swApp.ActiveDoc
    Set swModelDocExt = swModel.Extension
    boolstatus = swModel.ExportFlatPatternView(filePath, 0)
End Function
I am not calling SaveAs in this function as it is performed later in the macro (this is only part of a larger automation workflow).
The function works fine and exports the DXF correctly. My only problem is that when ExportFlatPatternView is called, a SaveAs dialog pops up to force me to save the part before proceeding.
How can I avoid / suppress this SaveAs dialog?
