I am trying to check someone's work.
Can someone share how to set up an FEA study for this simple part? (Maybe it isn't as easy as I think?)
I am trying to validate the force needed for a leg to fail under these conditions.
It has 750 pounds of downforce. The top plane should be restrained. How much force would be needed to have the weld joints fail?
I have attached a file if that helps.
Any help is greatly appreciated.
You are going to get much better results with a hand calc out of Shigleys for a welded joint in pure shear. Get the allowables from AISC 360 if it's in fatigue.
