We currently have an add-in in EPDM that can generate a PDF of a specific drawing (either manually or during specific state change).
Ideally I would like a "server" machine do all the work and push the PDF back to a folder on the end users machine.
We do NOT want to store it in EPDM. We do NOT want to use a network folder.
Any idea how this could be accomplished?
You should be able to accomplish this..
Are you using the convert task for this?
Set the server computer as the task host. Whatever folders you have on the originators machines you want these stored to, make sure they are shared folders so the server can access them to save there. (You may not have to do this though)
In the convert task options you can allow the user initiating the task to decide where it is saved as well as some other options. This can be outside the vault wherever they choose.
