Not able to extrusion after a corner feat
Question asked by Charles Robin on Mar 13, 2015
Latest reply on Mar 16, 2015 by Hernan Moran
Good Morning
Very often I'm not able to remove material 'or extrusion boss' after the sheet have been closed corners (corner feat).
Basically, I have to raise the bar in the design tree, to make a recovery, before the corner feat, in order to do an operation outlined as simply as a circle. Otherwise I had simple message:
Construction error: "The operation to fail because of the geometry" or "The function could not cut the body"
I SolidWorks 2013, when I publish some room formerly designed, SW load with no problem, but if I publish a hill, creating upstream closed corners, he does not know rebuilt, although the dimensions are the same .
Do you know this? you know a solution?
thank you very much
