3 Replies Latest reply on Mar 13, 2015 3:54 PM by Attilio Colangelo
    how to select defined loads?
    Frantisek Menda
      Hi all,
      I have manually defined different external loads in simulation static study. I want to write a script that will do several studies, always with different external load. Can I select somehow by API previously defined external loads?
        • Re: how to select defined loads?
          Attilio Colangelo
          This is a sample for programmatically getting an existing pressure load and changing it's value.  Note that the "pressureLoad" is Dim'd as CWPressure and any load you are trying to retrieve needs to Dim'd accordingly.
          Dim ActDoc                  As CosmosWorksLib.CWModelDoc
          Dim COSMOSWORKS             As Object
          Dim CWObject                As CosmosWorksLib.CWAddinCallBack
          Dim pressureLoad            As CosmosWorksLib.CWPressure
          Dim LBCMgr                  As CosmosWorksLib.CWLoadsAndRestraintsManager
          Dim swModel                 As SldWorks.ModelDoc2
          Dim StudyMngr               As CosmosWorksLib.CWStudyManager
          Dim Study                   As CosmosWorksLib.CWStudy
          Dim errCode                 As Long
          Set swModel = swApp.ActiveDoc         'Should be a partdoc object
          Set CWObject = swApp.GetAddInObject("SldWorks.Simulation") 'This works for Solidworks Simulation 2015
          Set COSMOSWORKS = CWObject.COSMOSWORKS
          Set ActDoc = COSMOSWORKS.ActiveDoc()
          Set StudyMngr = ActDoc.StudyManager()
          Set Study = StudyMngr.GetStudy(0) 'Zero based index of the number of studies in the model
          Set LBCMgr = Study.LoadsAndRestraintsManager
          Set pressureLoad = LBCMgr.GetLoadsAndRestraints(1, errCode) 'This is a zero based index. Pressure is
        'the second load or restraint
              pressureLoad.PressureBeginEdit
              pressureLoad.Value = 200
              pressureLoad.PressureEndEdit
