Using a macro change all pages to have the same CustomPropertyView View #.
Question asked by Joe Walton on Mar 12, 2015
Latest reply on Mar 12, 2015 by Joe Walton
     Alright, I've looked everywhere and I can't seem to find a true answer, if there even is one.
     I have a macro that will traverse all my drawing sheets and update my drawing sheets and this works fine.  While updating the sheets, I also want all sheets to have the same custompropertview View #, which just so happens to be on page #1.  Currently I can get page 1 to set to the view on page 1 (Ex: Drawing View1).  The problem is that I can't get Drawing View1 to be set for Page 2 and more because Drawing View 1 only exists on Page 1.
     The manual solution is to go to each page, right click, go to properties and in "Use custom property values from model shown in:" drop down select Drawing View 1.
     I can't rely on "Default" as the property to use because not all drawings have started on page 1 hence "Default" doesn't always represent Drawing View 1.
     I currently have Solidworks 2015 SP 2.0 installed.
Here is my code:
    Dim swView                      As SldWorks.View
    Dim bRet                          As Boolean
    Dim vSheetNames           As Variant
    Dim Fsheet                      As sheet
    Dim Osheet                      As String
    Dim Name                        As String
    Dim vSheetProps             As Variant
    Set swModel = swApp.ActiveDoc
    Set swDraw = swModel
    Set swSheet = swDraw.GetCurrentSheet
    'get list of sheet names
    vSheetNames = swDraw.GetSheetNames
    'get current sheet name
    Osheet = swSheet.GetName
    'Go to First Sheet
    bRet = swDraw.ActivateSheet(vSheetNames(0))
    Debug.Print "First Sheet " & vSheetNames(0)
    'Get First Sheet View Name
    Set swView = swDraw.GetFirstView
    Set swView = swView.GetNextView
    Name = swView.GetName2
    Debug.Print "First View " & Name
    'Set sheet custom property name to view
    swSheet.CustomPropertyView = Name
    'Traverse all sheets and change view property
    For i = 0 To UBound(vSheetNames)
        Debug.Print "********************************"
        bRet = swDraw.ActivateSheet(vSheetNames(i))
        Debug.Print "Sheet " & vSheetNames(i) & " before - view " & Name
        'Place "Default" to change all the pages to be default view, which didn't work correctly.
        'Name = "Default"
        Debug.Print "Sheet " & vSheetNames(i) & " after - view " & swSheet.CustomPropertyView
    Next i
    'Go Back to original sheet
    bRet = swDraw.ActivateSheet(Osheet)
