Compile error with "Dim value As System.Integer"
Question asked by Bo Tinggaard on Mar 12, 2015
Latest reply on Mar 12, 2015 by Santosh Pawar
Hello
I have just made a macro, that is exporting an Indented BOM table from any 3D file, and that works :-)
I what the Indented BOM to be with detailing index numbering and to do what i found some other thread that lead me to:
2013 SOLIDWORKS API Help - NumberingTypeOnIndentedBOM Property (IBomFeature)
But when I'm running this I end up with a Compile error... I have tried to uncheck the library files and recheck them, but I still gets the compile error:
My references:
My code:
'Get create an Indented BOM list and export it in fileformat .txt, from any 3D file.
Dim swBOMTable As SldWorks.BomTableAnnotation
Dim swTable As SldWorks.TableAnnotation
Dim swAnn As SldWorks.Annotation
Const BOMTemplate As String = ""
Const OutputPath As String = "C:\Tempfile\"
Dim ConfigName As String
Dim sModelName As String
    Set swModel = swApp.ActiveDoc
    'Create the direktory if it dosn't exit
    If Len(Dir(OutputPath, vbDirectory)) = 0 Then
        MkDir (OutputPath)
        MkDir (OutputPath)
''''''''******This part of the code is copy paste from SolidWorks API help (NumberingTypeOnIndentedBOM Property (IBomFeature))*****''''''''''
Dim instance As IBomFeature
instance.NumberingTypeOnIndentedBOM = value
value = instance.NumberingTypeOnIndentedBOM
    'Choose Configuration
    ConfigName = swModel.GetActiveConfiguration.name
    'Generate and choose BOM type
    Set swBOMTable = swModel.Extension.InsertBomTable(BOMTemplate, 0, 0, swBomType_e.swBomType_Indented, ConfigName)
    Set swTable = swBOMTable
    'Gets name from 3D file and remove extension
    sModelName = Left(swModel.GetTitle, InStrRev(swModel.GetTitle, ".") - 1)
    'Save file in path and create filename
    swTable.SaveAsText OutputPath & "BOMTable_Indented_" & sModelName & ".txt", vbTab
    Set swAnn = swTable.GetAnnotation
    swAnn.Select3 False, Nothing
    swModel.EditDelete
The error message:
I'm running, SolidWorks 2013 sp3
Any idea of what I doing wrong or missing?
/Bo
