I'm pretty sure that plot is for the last iteration. I don't
know if it is possible to keep all the other plots as well.
A side note, when you run a design scenario, I like to keep my LAST
set as my initial values, so that I end up with my original model.
Your model will keep the last dimensions in the design scenario
sets. (at least in 2004 it does, but I'm pretty sure it is still
that way)
Peter, you are correct in that CW only saves results for the
last set in Design Scenarios and does physically change your model
with each Set so that the last Set defines the final state of the
model. Making your last Set your original data is an excellent tip!
I'll sometimes just re-run my first set (or the one with the
nominal values) when I've completed my DS study to do the same
thing.
No capability for full results in anything but last set as of 2007.
There is a back door for this expected in 2008 for Pro &
Advanced Pro users.
A side note, when you run a design scenario, I like to keep my LAST set as my initial values, so that I end up with my original model. Your model will keep the last dimensions in the design scenario sets. (at least in 2004 it does, but I'm pretty sure it is still that way)
