So when i use the middle mouse wheel to rotate my view on the part or assembly i am editing, 9 times out of 10, it will zoom my view waaaaaay off into space so i can no longer see it. so i then have to either make my view trimetric or whatever in order to see it again, which resets my view and messes me up. I'm sure i'm not the only person who's had this issue as it isnt a hardware issue. i've tried using a standard logitech, a wacom tablet, and a razer naga (favorite for solidworks), and each one has had the same issue which leads me to believe that the software allows the user to middle mouse through the assembly, and set the point of rotation some 5 billion units of measurement away causing me to reset it every time. is there any way to limit how far off my view rotation's center can be from the assembly? or am i out of luck.
I have the same problem with my 3D mouse as well, usually i'll just press "F" to bring everything back in, but it still screws up the view I was working in.
